Call Forwarding on Koodo Prepaid: Is it Possible? / Does it Have a Cost?
I am enrolled in Koodo Prepaid. My phone (Windows Phone) has a feature called Call Forwarding; I would like to use this to forward calls to my home number when I am at home. My questions: 1. Is it even possible (again, using Koodo PREPAID)? When I attempt to set it up (using my phone), I receive an error message "Koodo : There was a problem with this code." 2. Assuming it's possible, is there a per-minute charge / talk booster usage when somebody calls me & I take the call on my home phone. Please: Authoritative answers only, thanks. Intended primarily for Koodo Support. Attn: Koodo Support - where is this specified in the Terms & Conditions?
Best answer by Tayeb Koodo 8 June 2014, 19:19
Hi Ian, Call forwarding is not available on prepaid but we do offer it on our monthly service. If you're ready to make the switch, this feature can be added to a plan for $3 per month: http://koo.do/koodoadd-ons. Thank you! ************************************************ If you see a good answer, give it a star.
If that is the case, why does my base plan specifically say it includes call forwarding as long as I have minutes, which I do.
It does say that. I have heard that a person is very lucky to get it to work though.
Have you tried to get it working and it wont work? The thread is 4 years old so the responses might not apply now.
Regardlessof what your handset says no "premium" services such as
  • Call Forwarding
  • Free EXT Roaming within Canada
  • WiFi calling or
  • VoLTE work on prepaid.
  • Call Forwarding
  • WiFi calling or
It's not what the handset says. It's what the prepaid base plan says is included.
https://www.koodomobile.com/prepaid-plans?INTCMP=KMNew_NavMenu_Shop_PrepaidPlans
  • Call Forwarding
  • WiFi calling or
Even if these features have worked on your phone using another carrier or Koodo post-paid, they are not supported on the prepaid network. Call Forwarding has been an advertised feature among the prepaid plans, but does not work.
Yes, I get similar error messages.
  • Call Forwarding
  • WiFi calling or
Well, that's certainly annoying.
  • Call Forwarding
  • WiFi calling or
Very. Alot of things with their prepaid service needs help. Main thing is though, don't offer what you can't deliver.
