block callers
Why is it when you block a caller, they can still get through & leave a voicemail? If they are blocked, they should not be able to leave message. Thanks
Blocking a call from your phone simply instructs the phone to ignore calls from that number. From that point they're treated the same as any other unanswered call. There are apps that will answer calls from blocked numbers and immediately hang up, but since these are completed calls, be aware that each call blocked this way would use 1 minute of airtime.
If it’s robo-callers that you are trying to prevent you may want to consider turning on a free feature we offer:
Call Control:
https://www.koodomobile.com/en/help/call-control
