Anytime minutes concern
I have a $44 plan with Tab Medium and I was supposed to get up to 500 Canada-wide anytime minutes but according to the Self-serve I have only 167 airtime minutes. Why is that? or is it different or what?
You must be new which means you are starting in the middle of your billing cycle which means you will have a pro-rated amount of minutes
Dennis wrote:
You must be new which means you are starting in the middle of your billing cycle which means you ...
Pro-rated minutes and pro-rated billing for the first month! It'll be normal once you past that cycle!
