4G LTE-Advanced Category / Bands Required
What is the fastest LTE-Advanced category supported by Koodo?
And what LTE bands are required to achieve it in the GTA?
I guess Cat 4+/almost-6? Telus (parent company of Koodo and same network Koodo uses) now claims up to 225mbps for LTE-A. It would be on 2600mhz atm. Although it seems that 700mhz is also being used for LTE-A, presumably in more rural areas. And 850/1900 for use on CDMA is also being reused for LTE/LTE-A as CDMA gets shut down, so it's kind of a mess. 2600 is the primary AFAIK.
So how many bands (and which bands) does a phone need to have, to be aggregated to obtain the current maximum LTE speed, anywhere near the 225mbps advertised in the Toronto area?
This is where it gets tricky an isn't made easily public. Since 2600mhz is the go-to spectrum for LTE-A, I would say the phon needs to have cat 6 and 2600mhz band for LTE to get the most speed in Toronto.
This is probably the most information I have found on the topic so far, but don't know how accurate it is. I was hoping for a more definitive answer here from a Koodo representative but I didn't think it would be so secretive.
https://en.wikipedia.org/wiki/Telus_Mobility#Radio_frequency_summary
Bumping this in hope for a clear, definitive answer.
Why did you ask, by the way?
Not sure if there is a "definitive" answer when they are upgrading their network...
https://mobilesyrup.com/2017/06/01/telus-can-now-deliver-quad-band-lte-a-to-the-samsung-galaxy-s8/
https://mobilesyrup.com/2017/09/27/telus-almost-reaches-1gbps-lte-a-speedtest/
https://mobilesyrup.com/2017/07/18/telus-debuts-quad-band-lte-in-almost-40-new-markets-in-canada/
The other side of the coin: how long do you think it will take to consume your entire monthly data allotment at those speeds if you tap/click on the wrong item?
I like the fact that reports say something might take 3-4 hours currently, so that I can choose to decline an obvious mistake.
Does this clarify things more?
