ZTE Nubia Z9 mini and 4G
  • Updated 1 year ago
Hello everyone,
I brought ZTE Nubia Z9 mini from China last week and can't get 4G on Koodo in Scarborough (the phone supports FDD-LTE B1/B3/B7). Yet, when i go to system menu and force the phone use LTE only, i get 1 bar of 4G.. How strong is Koodo's 4G around Toronto?
Photo of Vitaly Valkov
Vitaly Valkov
Posted 3 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
I tried checking the specs and it seems optimized for carriers in China, not Canada. It says it supports 3G bands 850/1900 but none of the LTE bands (1700/2100). Try setting the phone to HSPA/WCDMA only and that should help it along. You won't get LTE signal here but regular HSPA should work fine, unless the phone is programmed only for Chinese carriers with CDMA.
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
 Koodo/Telus network supports:
3G HSPA+ : 850/1900 MHz.
LTE :  band 4(1700/2100 MHz).
Your phone does not support band 4 so  you will not get LTE
If its showing 4G,  That's not LTE .   4G in north america is what's referred to as Fake 4G which is on HSPA+ network which is about 3 times faster than 3G but about 1/4 the speed of LTE.
Photo of Spence
Spence
and set to HSPA/WCDMA only as Jonathan mentioned
Vitaly Valkov
Doesn't Koodo support 2600MHZ (band 7)?
Photo of Spence
Spence
No , Band 4 only (1700/2100 MHz)  for LTE
Vitaly Valkov
will I get LTE anywhere in Canada with this phone though?
Photo of Ivan
Ivan, Mobile Master
Koodo does support band 7 now.
Vitaly Valkov
just checked HSPA+ speeds in my room. Download - 26.60 Mbps / Upload - 3.50 Mbps, twice as fast as my wifi =\
What are the speeds on LTE then?
Photo of GustavoWoltmann
GustavoWoltmann
  • 80 Points 75 badge 2x thumb
I didn't use Toronto, but I'm thinking to bring one.... I got Info about this in here, maybe it can help  you too..   http://www.china-prices.com/phone/840/zte-nubia-z9-mini
