Z10 battery charger not providing sufficient power
My Z10 charger not charging. I am using the charger that came with the Z10. The error symbol represents that the charger is not providing adequate power. I entered into contract with koodo on May 14 in Winnipeg Canada.
Photo of Nisheeth Verma
Nisheeth Verma
Photo of Rocky Balboa
Rocky Balboa
Try using a different battery... You may have to visit a Koodo kiosk to see if they have any in stock. Koodo might be able to send you out a replacement battery. Not sure if they would since this is a discontinued phone... Might need extra info from other posters on here...
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
As long as the phone's battery code is in the help files, Koodo can still send a battery. They still have a Galaxy Ace battery listed and those phones were garbage.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
What do you mean the Z10 has been discontinued Koodo still sells it?
Rocky Balboa
Excuse me you you should be able to call in to customer service to replace the battery. They are still selling in and The phone should be within the warranty because the phone hasn't been out for 1 year yet.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
Small thought but have you tried a different outlet?
The Z 10 at times has shown me this symbol as well. I use a 2.1 amp charger now for everything. They are readily available at future shop or online. Try one.
+1 on fail (or should that be -1) oh well a better charger works.
Photo of Ivan
Ivan, Mobile Master
I haven't had that happen on my Z10 (no longer in my possession), but I haven't used it nearly as much as you have. You have the ultimate BB10 authority around here ;)
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
The 2.1 amp travel charger is amazing. I use them exclusively. Rapid charging ftw.
Photo of mattjs
mattjs
Also, just throwing it out there, OS 10.2.1.1055 is incredible. Install android apps direct from android app stores right on the phone, no more sideloading ;)
I find when it's awake it's a power hog, with each new is leak the battery life is getting better. But sadly yes the supplied charger isn't enough. It doesn't happen all the time but it does happen. As said I have 2.1a chargers all over the house and in my truck. They do just fine.
Interestingly the 520 charger does a good job too unless you go to use the phone, then the battery drains while charging. During the day I use the 2.1a but when I'm sleeping it's on the 520's. Which I believe is .75 amps
Go figure and yes Mattjs 10.2.1 is amazing and the battery life is much improved
If you have a Source store near you drop by and check out their chargers, they carry a "Innergie" line that's great. I've had quite a few chargers and nothing charges as quickly as the Innergie one I got, its a 2.1A dual USB port charger that's truly a 2.1A charger when using one port which others I've had were not they had the same 1A output no matter if you were using 1 or 2 ports at a time, I highly recommend them and would even put my rep on the line
