Would my Blackberry plan work on a new iPhone 6? (please help!)
  • 2
Hi i have a question with concerns to koodo plans. Im currently on a koodo promotion plan which is a $45 with 1gb of data for my blackberry. Im thinking of switching over to the iPhone 6 soon and i was wondering if my data plan would work on the iPhone? Thanks
p.s: i can't switch my plan now because this promotional plan isn't offered anymore
Photo of hysan yeung
hysan yeung
  • 142 Points 100 badge 2x thumb
  • 2
Photo of Peter
Peter
  • 4,738 Points 4k badge 2x thumb
Hi Hysan Yeung,
Technically speaking, yes, your data plan would work on the iPhone 6 just fine (it just won't go through the BIS network if you were using a device pre-Blackberry 10).
Also, depending on your current Blackberry, you will likely need to get a new sim card (nano sim) for this to work with the iPhone 6 (no impact to your plan).
Hope this helps!
hysan yeung
Thanks for the reply Peter!
I am currently on a blackberry 9900 that i purchased unlocked as for the BIS network, that wouldn't affect my data usage on the iPhone 6 right?
Thanks again!
Photo of Peter
Peter
You should be all good!
