Wireless Home Phone: Where do I give the number I want to port in?
  • 2
  • Updated 4 months ago
  • (Edited)
During the initial sign up I had to give my full name, phone number, and email address. Is that phone number the one that can be ported or do I give the number after I receive the package?
The reason I'm asking is during the sign up I want to give my cell phone number, which I don't want to port in (I'm assuming this is the contact number?). I want to port in my landline.
Photo of TheUglyDuckling
TheUglyDuckling
  • 332 Points 250 badge 2x thumb
Posted 4 months ago
  • 2
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
I think you would need to port in the number afterwards when the account has been created.
TheUglyDuckling
So it's not the number I give during signing up that has to necessarily be ported.
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
Correct. You can port later.
TheUglyDuckling
Thanks all!
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
FYI, when you submit the port request, you will be asked for an alternate contact number. This number is how koodo will try to contact you if there is a problem with porting. It should NOT be the same number you are porting. That may seem obvious, but it happens often enough that it needs saying.
