Wireless home phone not working, just getting blinking orange battery light.
  • 2
  • Updated 1 year ago
Last night I bought the wireless home phone solution (ZTE WF721) and brought it home. Plugged it in and all I am getting is a blinking orange battery light. Nothing else is happening and I am unable to find any information on what this light means and what I need to do? I've called the store I bought it from but no answer. Any ideas of what this is and how to fix it?
Photo of Jason Pike
Jason Pike
Posted 1 year ago
  • 2
Photo of David
David, Mobile Master
  • 88,962 Points 50k badge 2x thumb
This document for a similar device suggests the battery may not be properly installed. Have you checked it?
Photo of Fred C
Fred C
  • 1,774 Points 1k badge 2x thumb
Hi Jason, try the Users Guide, I saw where it takes 5 hours to charge and orange means charging.
http://aide.koodomobile.com/Portals/0/Phones/PDF%20Guides/User%20Guide%20Final%20Copy.pdf
Photo of Jason Pike
Jason Pike
Yeah, I had it plugged in all night hoping that was the problem. But even after all that it's still blinking
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hey Jason,
I'm thinking that it is not getting power. Whenever it's on battery power, the light blinks. If you have a solid light, then you are getting power. Try using a different power outlet and confirming the power outlet is properly working.
Photo of Jason Pike
Jason Pike
I've tried a couple different outlets with no luck.
Photo of Mathieu
I'd recommend going back to the kiosk to swap it out then. Seems like something might not be working properly with the charging.
