Wireless charging
  • Updated 2 years ago
Will I be able to use a case and still use a wireless charger on the galaxy s7 edge?
Photo of josh
josh
  • 136 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,496 Points 100k badge 2x thumb
Generally, yes, but it would depend somewhat on the case.
Photo of josh
josh
So it doesn't have a back piece I have to put on the phone to make worm right?
Photo of Jonathan I
Jonathan I, Mobile Master
Nope, the S7 has it integrated into the device. When I had the S6, it worked through thinner cases bit not thicker ones. Honestly the only way you'll be able to know is by testing it out.
Photo of DaveZotzman
DaveZotzman
I have a pretty thick case on my S6 Edge and it was a bit fussy.  A little tip though, replace the cord from the wall plug to the charger with the shortest, thickest cord you can find.  It will reduce the resistance in the cable to the charger.  Now with my case on, I can toss my phone on way off center, crooked, whatever, and it works flawlessly.
