My phone is talking to me, how do I get it to stop?
  • (Edited)
why does my cell phone talks when I get a txt message or a call coming in, its says you have a message from than the name of the person who is sending me a txt and also say you have a call from than says the number that is calling my cell thanks
Photo of Ed Playfair
Ed Playfair
  • 200 Points 100 badge 2x thumb
Samsung?
Photo of Boolanger
Boolanger
  • 9,234 Points 5k badge 2x thumb
A lot of phones will have this feature which can be turned off/on in the settings.
Which phone are you using ?
Ed Playfair
l am using a Samsung cell phone
Some apps that use the accessibility services can also inadvertently turn on talk back service in some samsung devices.
Have you recently installed such an app? If you want to continue using it you'll need to disable the Google text to speech engine by navigation to
Settings...apps...running...
And Tap disable on the Google tts engine.
Ed Playfair
yes I know a man answered my question but don't know how to turn it off, dont understand how to do it the way he is saying to turn it of and I have not installed such an app or any app, it just stated doing this yesterday, I do not want the talk back service on ,i want to turn it off
Ed Playfair
I am using a Samsung cell
Ed Playfair
I am using a Samsung cell and I do not want to continue using this feature
Ed Playfair
I am using a Samsung cell and I do not want to continue using this feature, how do I turn it of so it stops talkin like that, thanks
Some brilliant,and dare I say incredibly handsome man, has answered your question above.
Ed Playfair
On your phone hit settings
First try going to accessibility and look to see if talk back is enabled
If it isn't.
You'll need to goto settings, apps,
Swipe on the screen to running applications
Disable the Google text to speech engine.
Ed Playfair
yes my talkback says off
So then you'll need to disable google text to speech engine.
Here is an app that may help you: https://play.google.com/store/apps/de...
Ed Playfair
thanks you for the help, but it didn't work at all cant not find google text at all and also had a friend look at it and he said the talkback is of all ready cause it says off were its says talkback
Ed Playfair
Even though talk back says it's off, there is a bug in some samsung phones that makes app's trigger talking.
Did you try the app I linked to above?
Ed Playfair
yes I did try the app and still the same
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,212 Points 100k badge 2x thumb
Is there an option that says driving mode?
Ed Playfair
were would I found driving mode ?
Typically under settings->language and input
Ed Playfair
ok I got in and were it says text to speech its had google text to speech checked and I unchecked it and checked Samsung tts will that fix it
Ed Playfair
ok it didn't matter if that was unchecked or not but its not talking now have no clue why its started or stopped
