Will Sony Xperia SP LTE C5303 work on the Koodo Network?
Hello,
I'm thinking of buying this phone online: http://www.expansys.ca/sony-xperia-sp...
Specs:
HSDPA 850 / 900 / 2100
LTE 800 / 850 / 900 / 1800 / 2100 / 2600
However Im not sure if it will work because Koodo works on HSPA 850/1900 and LTE 1700/2100 but this phone seems to have only two of those, HSDPA 850 and LTE 2100. Is there a difference between HSPA and HSDPA? Does this mean it wont work? does it need to have all 4 diffferent frequencies in order to work?
I tried inputing an IMEI number of an xperia sp i found on youtube and the koodo compatability check tool says it works but im not sure?:
Your IMEI - 356604051110301
XPERIA SP C5303
Your device should work on our Network.
Thank you so much!
Photo of Sammy Douglas
Sammy Douglas
  • 84 Points 75 badge 2x thumb
Primarily for HSPA koodo favors the 850mhz band so you should at least get good coverage although in some small areas which I can't name, you may have issues.
Same with LTE but truth be told, unless you're streaming movies and playing massive online multi-player intensive games, you could shut lte off and still have a great experience. I don't think you'll miss it really.
Sammy Douglas
so i take it that there is no difference between hspa and hsdpa?
Thank you!
Photo of Chris Petersens
Chris Petersens
In addition to Chad's comments, the Experia comes unlocked as far as I know, so you will save on that too. Ask koodo for the 10% off your monthly plan discount for bringing your phone.
