will my sim card work ?
I have a Telus sim card and im buying an Samsung s2x and i wanted to know if it will work or will i have to unlock it ?
Photo of Courtney DeWolfe
Courtney DeWolfe
  • 80 Points 75 badge 2x thumb
The phone will work but as far as unlocking
The only answer we can give you is ,Maybe
Some of the Koodo stock was sold unlocked and some was not unlocked and there's no way to tell
Also if you want to use koodo you need a koodo sim
If you do have to unlock it there are some reputable sites online like gsmliberty.com or eBay (make sure to read seller feedback)
Photo of Daniel Kim
Daniel Kim, Mobile Master
A telus sim card will not work on koodo's network. Also which carrier are you getting the S2x from? It will have to either be from koodo, telus, or unlocked to work with koodo.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
My understanding was she's with Telus, wants to buy a Koodo S2X and use it with Telus.
Courtney DeWolfe
yes thats what i mean! :P
Photo of Jorden
Chad's got the best answer for you. Some people have had luck going to Telus with the S II some have not. Only phones that will work for sure are the iPhones, anything else is hit or miss.
Photo of mathewjohn
mathewjohn
If you have a network free Samsung S2x phone means,you will be able to use your Telus sim card.Network locked phone means,you will need to unlock it.For unlocking you can approach your service provider or else try to buy an unlocking service from any one of the online unlocking service provider like http://www.simpleunlocking.com/samsun...
Photo of Ivan
Ivan, Mobile Master
Nope.
