Will my plan have to switch?
Looking to upgrade my phone. With the new tabs and plans, will I be able to keep my old plan if it stick with the small tab? If I want a medium tab will I have to switch my plan or will it just add on $5 a month for tab repayment?
Photo of Katie Carolyn Elizabeth Gibson-Hynes
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
Hi Katie, if your current plan is $30 or higher, you can choose between the Tab S and Tab M without changing your plan :)
If your current plan is below $30 you don't have to change it either, but you'll only qualify for the Tab S.
Either way you can definitely get yourself a new phone without being forced to upgrade your plan!
Sweet, thanks! It was the only deciding factor in getting my new phone!
  • 203,644 Points 100k badge 2x thumb
Just out of curiosity, what phone are you looking at getting?
Photo of Daniel Kim
Daniel Kim, Mobile Master
If expandable memory isn't a problem, I recommend either the moto g for free on tab S or the nexus 5 for 100 on tab M. These are just suggestions, the final decision is up to you :)
My last phone was Samsung so I wanted to go with a Samsung so it stayed pretty close to the same way to work my phone but thanks for the idea! I also like the small phone fits better i my small hands!
