Will my Koodo sim card work in a Telus iPhone 3G?
If it does not work, will unlocking it solve the problem?
Photo of James Gillis
James Gillis
Photo of Rocky Balboa
Rocky Balboa
Do you mean does your iphone 3g work on a telus network?you might have to clarify what you're asking.
Photo of Jorden
Jorden, Mobile Master
  • 33,404 Points 20k badge 2x thumb
From what I remember on here your iPhone 3G will likely need to be unlocked (only 3GS or higher worked without being unlocked), and I also believe I read that data will not work on an iPhone 3G only text/calling.
In the same token the iPhone 3G is a 5 year old device it may be more worth it to look at a newer device.
Photo of John Lee
John Lee
I suggest getting a new device... The iPhone 3G is extremely old.
Also, data services may not work since Koodo only supports the 3GS and up.
