Will a verizon Iphone 4s work on koodoo?
Will a verizon Iphone 4s work on koodoo? I want to get a used iphone and I'm looking at one thats on verizon from the states. can anyone provide any insight into this?
Photo of Irons7922 .
Irons7922 .
Photo of Daniel Kim
Daniel Kim, Mobile Master
Yep, as long as it's unlocked it will work but make sure the iphone 4s has a sim card slot. I'm pretty sure it has one since it supports both HSPA and CDMA but just make sure since verizon is a cdma carrier.
I suggest searching for a telus or a koodo unit since getting an iphone unlocked costs a lot so you either want to get an unlocked iphone or one thats locked to koodo or telus.
Photo of Ivan
Ivan, Mobile Master
Only the 4S needs to be unlocked. All Verizon phones with LTE are SIM-unlocked.
