Will a telus Samsung s4 work on the koodo network
I have seen in the faq that only the iphones are interchangeable between telus and koodo. Is the Samsung S4 interchangeable as well?
Photo of Stewart Gregg
Stewart Gregg
  • 90 Points 75 badge 2x thumb
The best advice I can give you is: try it
It's amazing how many locked devices may work between koodo and telus without needing to be unlocked.
If you visit a Koodo kiosk or retailer they can probably lend you a sim to try.
Photo of Robert
Robert, Mobile Master
  • 103,604 Points 100k badge 2x thumb
Considering it is a second hand phone bring your SIM with you and try it before buying it.
