Will A Koodo Sim card from an Android phone work on a Blackberry phone?
Photo of Ryan Blanchard
Ryan Blanchard
  • 160 Points 100 badge 2x thumb
Photo of Daniel Kim
Daniel Kim, Mobile Master
If it's the same sim card size then yes it will work :) If it doesn't fit you can get a new sim for 10 on postpaid and 20 on prepaid.
Photo of tshooz
tshooz
  • 2,936 Points 2k badge 2x thumb
It depends which BlackBerry device you want to use. The BB10 phones it will work fine given the SIM card is the same size. If you want to use a legacy devices you will have to upgrade your plan to include BB so all the features will work on that phone if not you will only be able to use it for calls and texts.
Photo of maya care
maya care
  • 90 Points 75 badge 2x thumb
If it's the same sim card size and your Blackberry phone is free of any network lock means it will work.If you have network restricted phone,you will need to unlock it.For unlocking you can approach your service provider or else try to buy an unlocking service from any one of the online unlocking service provider like http://www.mobileunlocksolutions.com/...
This comment is spam / scam koodo charges way less than this "service"
Photo of Steve
Steve
  • 4,030 Points 4k badge 2x thumb
The trick is to have the BB add-on (if it's an older BB). Although I primarily use Android phones I have an unlocked BB Curve as a backup phone and the BB plan works well for the Android and at the same price but the access to the BB features is there when I need them.
