Will a bold 9900 from wind mobile work with koodo?
Photo of HootSuite App
HootSuite App
  • 1,100 Points 1k badge 2x thumb
Photo of Jonathan I
Jonathan I, Mobile Master
It would need to be unlocked first... go to freemyblackberry.com to get a free code within 24 hours or pay $3 for an instant one.
Then we have to worry about frequency compatibility since Wind operates on a different spectrum than Robellus and their sister companies.
EDIT: I did some poking around the interwebs and it doesn't look like it's compatible.
Photo of rikkster
rikkster, Mobile Master
  • 66,312 Points 50k badge 2x thumb
UMTS: 2100/1900/850/800 MHz or 2100/1700/900 MHz
GSM/GPRS/EDGE: 850/900/1800/1900
The frequencies above say the BB 9900 should be compatible on Koodo's network, obviously it will have to be unlocked to be able to work on the network, but I've read conflicting reports that the device may not work, because the device is programmed to operate on WIND Mobiles' AWS frequencies only (2100/1700/900 MHz). Best option would be to call Koodo tech support to see if the BB 9900 will work on the Koodo network.
  • 203,644 Points 100k badge 2x thumb
If you have the phone now why not just check it with the IMEI tool koodo offers here:
Photo of Jonathan I
It's not 100% accurate but it is helpful.
Photo of HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
You can always go to a koodo kiosk and put in a koodo sim card and see if it will on our network once its unlocked . ^rikkster is 100 % correct though, its known that WIND phones dont work on the koodo network due to the diffrent frequencies.
