Will This Phone Work on Koodo?
  • Updated 9 months ago
  • (Edited)
Hi,
I would like to buy Leagoo T5 for my parents.
It's Network :
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 850/900/2100MHz
4G: FDD-LTE 800/850/900/1800/2100/2600MHz TDD-LTE B40
I searched Koodo's frequency band, but only one frequency in each 3G & LTE & LTE+ is compatable with this phone.
Will it work?
Thanks!
Hope you have a good weekend:)
Photo of AA AA
AA AA
  • 102 Points 100 badge 2x thumb
Posted 9 months ago
Photo of AA AA
AA AA
It also had the same information on the network:
Wireless Connectivity: 3G,4G,Bluetooth 4.0,GPS,GSM,WiFi
WIFI: 802.11b/g/n wireless internet
Network type: FDD-LTE,GSM,TDD-LTE,WCDMA
2G: GSM 1800MHz,GSM 1900MHz,GSM 850MHz,GSM 900MHz
3G: WCDMA B1 2100MHz,WCDMA B5 850MHz,WCDMA B8 900MHz
4G LTE: FDD B1 2100MHz,FDD B20 800MHz,FDD B3 1800MHz,FDD B5 850MHz,FDD B7 2600MHz,FDD B8 900MHz,TDD B40 2300MHz
Photo of Goran
Goran, Mobile Master
  • 90,074 Points 50k badge 2x thumb
You should get service. It was a point of contention for a bit but there should be voice service available with just 850 or 1900. 2600mhz will get lte in most of the Telus footprint. You could always gets a phone that is quad band 3g to be safe. The mediatek 6750 it houses is fairly limiting and not power efficient. I'd look to Xiaomi's offerings if you were going to import a Chinese OEM personally. Or so etching at least with a p20 if mediatek.
Photo of AA AA
AA AA
Thanks Gordan for your advice!
I think it would be better to buy xiaomi
Thank you again for your help!
Photo of BobTheElectrician
BobTheElectrician
  • 61,576 Points 50k badge 2x thumb
You will be much safer if you shop for gear that is advertised as AT&T or T-Mobile compatible. Many foreign suppliers will not know about Koodo. You can always check out
www.willmyphonework.net
Photo of AA AA
AA AA
Thank you for your help!
