Will this phone work on Koodo network?
It supports the following...
Can I buys it :)
3G:  HSDPA 850 / 900 / 2100
4g:  LTE 800 / 850 / 900 / 1800 / 2100 / 2600
(Bands 1, 3, 5, 7, 8, 20)
Photo of jakebanks5
jakebanks5
  • 606 Points 500 badge 2x thumb
  • hopeful
Posted 3 years ago
Photo of jakebanks5
jakebanks5
My current phone is almost entirely completely dead so I need to upgrade and I found a great deal online
Photo of jakebanks5
jakebanks5
no one cares
Photo of jakebanks5
jakebanks5
Also supports the standard 2G stuff, obviously
Photo of BobTheElectrician
BobTheElectrician
  • 67,356 Points 50k badge 2x thumb
Missing 1900 3G & 1700 4G/LTE, different band advertised. I wouldn't pay big bucks, especially without knowing the phone model & mfgr.
If you are trying to dig deeper, you will find more references to AT&T compatibility than Koodo, which is largely unknown to minor Asian mfgrs.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,524 Points 100k badge 2x thumb
It won't work properly on Koodo no. Koodo uses 850mhz and 1900 MHz which your device should be compatible with both of those frequencies. LTE Bands for Koodo are 1700mhz / 2100mhz these are not important unless you want LTE
Photo of jakebanks5
jakebanks5
Sony Xperia SP. So it requires both to work properly. Ok sirs. There is another model of this phone which I could start looking for, it supports.. ahem...
HSDPA 850 / 900 / 1900 / 2100
LTE 850 / 1700 / 1900 / 2100
I'm 'whiz' you guys are both epic vs me, but it looks like that's the one I want, yes?
BobTheElectrician
Much better choice. Please make my slice all-dressed.
Photo of jakebanks5
jakebanks5
Hahaha, will do, thanks.
