Will these phone work on the Koodo network (with prepaid plan)?
I have two question regarding coverage:
1, I'm wondering if the new OnePlus Two (OP2) works on the Koodo network. Its specification are:
Connectivity:
(North America version)
GSM: 850, 900, 1800, 1900MHz
WCDMA: Bands 1/2/4/5/8
FDD-LTE: Bands 1/2/4/5/7/8/12/17
2, the same question, but for a different phone (Samsung galaxy S5 MINI). Its specs are:
Network: 2G GSM, 3G WCDMA, 4G LTE FDD
2G GSM: GSM850, GSM900, DCS1800, PCS1900
3G UMTS: B1(2100), B2(1900), B5(850), B8(900)
4G FDD LTE: B1(2100), B3(1800), B5(850), B7(2600), B8(900), B20(800)
Thanks
Photo of goshoz
goshoz
  • 82 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Dennis
Dennis, Mobile Master
  • 196,080 Points 100k badge 2x thumb
Koodo uses
3G HSPA+ 850/1900
4G LTE 1700/2100
Soooo....
1) 3G yes.  LTE yes
2) 3G yes.  LTE no
Photo of goshoz
goshoz
So does that mean that with number 2) I would be able to call/text, but cannot use data?
Photo of Dennis
Means you can use data at 3G speeds but not LTE speeds
Photo of Ivan
Ivan, Mobile Master
3G speeds aren't exactly slow either. I keep my LTE off and get by just fine.
Photo of Taylor
Taylor
  • 250 Points 250 badge 2x thumb
I would suggest you take the phones into a shop and have them use an active SIM before committing. Remember Koodo cannot guarantee service of a device that they did not provide.
Photo of Ahmad
Ahmad
This is honestly a waste of time unless you don't know the phone's specs.
