Will the Zenfone Max work on the Koodo network?
  • Updated 2 years ago
Will the Zenfone Max work on the Koodo network? I believe it will just want to be sure. These are the specs - 2G GSM : 850MHz/900MHz/1800MHz/1900MHz 3G WCDMA :2100MHz(1)/900MHz(8) TD-SCDMA: 2100MHz(34)/1900MHz(39) 4G :FDD-LTE: 2100MHz(1) /1800MHz(3) TDD-LTE: 2600MHz(38) /1900MHz(39)/2300MHz(40)/2500MHz(41)/(2555-2655MHz only).
Photo of Ned
Ned
Posted 2 years ago
Photo of Tiz
Tiz
  • 4,604 Points 4k badge 2x thumb
No, the frequencies used by Koodo are:
3G (and fake 4G)HSDPA 850/1900
HSPA+ 850/1900
UMTS 850/1900
WCDMA 850/1900
1x EV-DO CDMA2000
4G (called 4G+)
LTE 1700/2100
Photo of Brent
Brent
The phone will work. He will be limited to 3G speeds
Photo of Ivan
Ivan, Mobile Master
According to the original specs in the original post, the phone will not work. Unless those specs are incorrect.
Ned specified the phone having WCDMA 900/2100, while Koodo requires 850/1900.
Photo of BobTheElectrician
BobTheElectrician
  • 67,408 Points 50k badge 2x thumb
For future quick-checking:
http://willmyphonework.net/
Photo of Brent
Brent
Possibly the most useful website ever. Especially if you're traveling to another country and using a local sim. Helped me when I went to Australia
Photo of Goran
Goran, Mobile Master
  • 97,448 Points 50k badge 2x thumb
I suggest picking up a regular Zenfone 2 or a Zenfone 2 Laser, unless you currently own a Zenfone Max.
Photo of Daniel
Daniel, Employee
  • 5,714 Points 5k badge 2x thumb
Hi Ned!
You can confirm here http://koo.do/1aU1u0o if you have the IMEI of the device. Hope that helps :)
