Will the new Ulefone Power work with Koodo
  • Updated 4 months ago
Trying to find out if the New Ulefone Power will work on the Koodo Network.
The frequency coverage is
GSM: 850/900/1800/1900 (band5,band8,band3,band2)
WCDMA: 900/2100 (band8,band1)
FDD-LTE: 800/900/1800/2100/2600 (band20,band3,band1,band7,band8)
It will be running on Android 5.1 and going to 6.0
Dual sim dual standby
Both SIM slots are compatible with 4G, respectively. When they work at the same time, only one of them can receive LTE service and the other GSM. You can choose in settings which one for 4G.
Photo of FT Pont
FT Pont
  • 112 Points 100 badge 2x thumb
Posted 2 years ago
The device, as you posted it, isn't compatiable With koodo.
Photo of FT Pont
FT Pont
Thanks for your quick reply.
The information was from the manufacturers site.
Why Not , Lack of Band 5 coverage ?
Photo of Allan
Allan, Mobile Master
  • 57,086 Points 50k badge 2x thumb
According to that link it should be fully compatible.
Photo of Roman Holovatch
Roman Holovatch
  • 82 Points 75 badge 2x thumb
Thank you. Can you also check this one and tel me if its compatible with Koodo?
https://www.ebay.ca/itm/Doogee-S60-Android-Phone-QI-Wireless-Charging-Octa-Core-6GB-RAM-Android-7-0/...
Photo of Goran
Goran, Mobile Master
  • 91,244 Points 50k badge 2x thumb
You can select item description and match up the bands with the ones I named that are needed. I can tell you yes, because it is, but it would really be ideal for you to see for yourself.
Photo of Caleb MacMillan
Caleb MacMillan
Ya im uber confused how this stuff works will the ulefone armor wirk with koodo
