Will the Huawei p10 lite work with koodo?
  • Updated 1 month ago
Will the Huawei p10 lite, WAS-LX3 work on koodo's network? Description says Cellular Network Supported: 4FDD LTE: Band 2/4/5/7/28 UMTS (WCDMA) / HSPA+ / DC-HSDPA: Band 1/2/4/5/8 GSM / EDGE: 850/900/1800/1900 MHz Secondary SIM card: GSM: 850/900/1800/1900 MHz. Not sure what this means
Photo of Christina .
Christina .
Posted 12 months ago
Photo of Dennis
Dennis, Mobile Master
  • 196,140 Points 100k badge 2x thumb
The secondary SIM is 2G only and Koodo does not have a 2G network.
For the Primary sim, the LTE and 3G will work fully
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
So you would need to insert it into the primary SIM tray for it to work! The secondary SIM will be more or less useless
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
@Dennis:
How do you know that it's the dual-sim variant?
@Robert:
Could put Koodo sim in 2nd sim slot if roaming internationally for the sake of receiving SMS via 2G roaming. For the most part, 2G is not too useful in Canada, though.
Photo of Dennis
  • 196,100 Points 100k badge 2x thumb
OP posted the description above that says secondary sim card
titaniumtux
@Dennis:
Ah I see it now.
Hi, I have a Huawei P10 Lite (WAS-TL10) and I can't get LTE, I only get HSDPA and HSDPA+.
These are the bands it supports:
2G:1800MHZ, 1900MHZ, 850MHZ, 900MHZ,
3G: 1900MHZ, 2100MHZ, 850MHZ, 900MHZ,
LTE: 1800MHZ, 2100MHZ, 2300MHZ, 2600MHZ.
Thanks.
I went to a fido kiosk today  and they tell me that it should work but when we test with a fido sim card, it only got HSPA/HSPA+ (as far I know that is 3G). I'm in Montreal and but I can't get signal when I'm in the metro (even 3G) and that is weird to me.
When you change your phone you have to notify koodo in some way?
Photo of srlawren
srlawren
  • 4,280 Points 4k badge 2x thumb
I have no idea what kind of coverage is in place in the Metro in Montreal, since I'm in Vancovuer area.  I know out here, there are a few underground sections of our "skytrain" (rough equivalent to the metro, but mostly above ground) that have zero coverage on Telus/Koodo/Bell/Virgin, as they have exclusive agreements with Rogers/Fido/Chatr and Freedom Mobile, sadly.  Maybe the Metro is similar?
As to your phone:  it lacks LTE Band 4 (which uses a combination of 1700MHz and 2100MHz simultaneously--having just 2100 is not sufficient for band 4), thus you are missing the primary LTE band on the Koodo (Telus) network.  You may only get HSPA+ at best in many areas.
Photo of Allan
Allan, Mobile Master
  • 62,372 Points 50k badge 2x thumb
Like i mentioned above. If you want full compatibility you will want a different phone.
Photo of vondes
vondes
  • 80 Points 75 badge 2x thumb
Hello, can u say something about a track phone mobile recorder on Android. How can we use this application in our phones?
Photo of Dennis
@vonders this question will probably be better asked to the app maker than with koodo
