Will the G900V Samsung S5 work for Koodo and LTE?
  • Updated 2 years ago
2G bands
CDMA 800 / 1900 - all versions   GSM 850 / 900 / 1800 / 1900 - SM-G900V, SM-G900P
3G bands CDMA2000 1xEV-DO - all versions   HSDPA 850 / 900 / 1900 / 2100 - SM-G900V, SM-G900P
4G bands LTE band 4(1700/2100), 13(700) - SM-G900V   LTE band 2(1900), 4(1700/2100), 5(850), 12(700), 17(700) - SM-G900R4   LTE band 25(1900), 26(850), 41(2500) - SM-G900P Speed EV-DO Rev.A 3.1 Mbps, LTE Cat4 150/50 Mbps, HSPA
GPRS Yes
EDGE Yes
Photo of Jason Leong
Jason Leong
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,212 Points 100k badge 2x thumb
Should work just fine.
Photo of Goran
Goran, Mobile Master
  • 90,940 Points 50k badge 2x thumb
willmyphonework.net will tell you if it will work with whichever network of pretty well any carrier.
Jason Leong
thanks guys
Photo of Ivan
Ivan, Mobile Master
Do you ever visit the States? Modern Verizon phones have an unlocked SIM card slot for international use, meaning that you'll be able to use it just fine in Canada, but once you cross the border you will not be able to connect to roaming partners as it will try to connect to Verizon only.
