Will the Cat S60 work with Koodo?
  • Updated 7 months ago
Just got an email update on the Cat S60 phone.
The email says "The Cat S60 is Carrier-unlocked and may be used with any GSM network - please check with your carrier if unsure."
 I know that Koodo doesn't support GSM.  However, Koodo should support this phone on HSPA or LTE?  Can someone confirm that I am correct in believing this phone supports more then GSM.  I do not understand, why the email only mentions GSM support.
Here is what the documentation section says:
Technology:GSM / HSPA / LTE
2G:GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3G:HSDPA 850 / 900 / 2100 - Global
      HSDPA 850 / 1700(AWS) / 1900 - North America
4G:LTE band 1(2100), 3(1800), 7(2600), 8(900), 20(800) - Global
      LTE band 2(1900), 4(1700/2100), 5(850), 7(2600), 12(700), 17(700) - North America
Speed:HSPA, LTE Cat4 150/50 Mbps
Thank you for your help.
Photo of Vanessa
Vanessa
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 90,584 Points 50k badge 2x thumb
It will work with both 3g and LTE networks. Also you can use for the future willmyphonework.net to see about practically a phone an carrier in the world.
Photo of BobTheElectrician
BobTheElectrician
  • 61,868 Points 50k badge 2x thumb
The second SIM slot on dual SIM phones typically only covers 2G voice connections, common in Asia, but which have been for the most part been phased out in Canada. That may explain the mention of GSM not being compatible.
The main SIM will do anything you want in Canada and the US, but you should investigate further if the second SIM is critical to your purchase decision.
Photo of Goran
Right yes. GSM is often used to refer to Sim card accepting phones but is technically 2G network technology. So the seller is saying if the network uses Sim cards, you're good to go.
The North American version will work with koodo.
The global version will not.
Photo of Vanessa
Vanessa
thank you everyone.  i will pre-order it today.
Photo of Tony P H Appelboom
Tony P H Appelboom
  • 158 Points 100 badge 2x thumb
How is your s60 on the koodo network, I am considering a cat s41
Thanks
