Will Oukitel Mix 2 work on Koodo as a prepaid customer in rural Saskatchewan?
  • Updated 2 months ago
Type: WCDMA, GSM, FDD-LTE
2G Bands: GSM 850/900/1800/1900MHz
3G Bands: WCDMA 900/2100MHz
4G Bands: FDD-LTE 800(B20)/900(B8)/1800(B3)/2100(B1)/2600(B7)MHz
WIFI: 802.11 b/g/n/, Hotspot
GPS: Yes, A-GPS, GLONASS
Bluetooth: V4.2
Photo of Pauline
Pauline
  • 172 Points 100 badge 2x thumb
Posted 2 months ago
Photo of Ray
Ray
  • 7,674 Points 5k badge 2x thumb
This phone is not compatible with most Canadian network frequencies.
Koodo doesn't have a 2G network (Rogers is the only network in Canada that does have 2G). Supported frequencies for 3G are 850 and 1900 MHz. For 4G LTE you need band 4 (1700) or 7 (2600) but coverage may be limited for band 7.
Photo of Pauline
Pauline
So the Asus zenfone 4 max won't work either!?
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
According to here: https://www.gsmarena.com/asus_zenfone_4_max_zc554kl-8749.php
The Canada/USA model will be compatible with Koodo.
Photo of Ray
Ray
The 5.5" model ZC554KL will work, if it's the US/Canada model. The 5.2" model appears to be missing 1900 MHz for 3G but does have the appropriate bands for LTE.
Photo of Pauline
Pauline
I think the one I am looking at is the International model.
Photo of Allan
You are looking for the following:
3G: 850 and 1900MHz
LTE: Band 4 (1700/2100MHz)
LTE-a: Band 7 (2600MHz) and 700MHz
You need at least one of the 3G bands but it is highly recommended to have both as service will be spotty otherwise. If you want LTE you need Band 4, and LTE-a isn't necessary but definitely nice to have if you use data frequently.
Photo of Pauline
Pauline
I really appreciate your help. Thank you.
Photo of Pauline
Pauline
I am looking at the Koodo coverage map. What do the pink and green colors represent?
Photo of Allan
  • 51,184 Points 50k badge 2x thumb
There is a legend beneath the map.
Pink is LTE-advanced, Green is LTE, Blue is HSPA or 3G
Photo of BobTheElectrician
BobTheElectrician
  • 61,736 Points 50k badge 2x thumb
You can check out
www.willmyphonework.net
If you are buying from overseas suppliers who don't mention Canadian networks, look for gear that is AT&T or T-Mobile compatible.
On the coverage map, clicking on Koodo coverage  and then the BigGuys yields identical results since those are common towers (Bell, Virgin, Telus, Koodo, PublicMobile). The other big guys I presume are Rogers, who have different towers.
Photo of Pauline
Pauline
Thank you
Photo of Pauline
Pauline
Will Global Version Xiaomi Redmi 5 Plus 4GB RAM 64GB and
Global Version Xiaomi Mi A1 4GB RAM 64GB ROM work on Koodo?
Photo of Pauline
Pauline
Xiaomi redmi 5 plus: 4G: FDD-LTE 1/3/4/5/7/8/20
Xiaomi mi a1: 4G: TD-LTE 38/40 FDD-LTE 1/3/4/5/7/8/20
Photo of Allan
Both are fine for LTE.
Make sure they have 850 and 1900 for 3G as well and you're all good!
Photo of Pauline
Pauline
Redmi 3G: WCDMA 1/2/5/8
Mi A1 3G: WCDMA 1/2/5/8
Photo of Goran
Goran, Mobile Master
  • 90,426 Points 50k badge 2x thumb
That's the standard quad band of 859/900/1800/1900mhz or 1/2/5/8. You're good.
Photo of Pauline
Pauline
Thank you. I appreciate your time.
