Will my Telus iPhone 6 work with Koodo ? Is it 100% guarantee that it will work?
  • 2
  • Updated 1 year ago
Photo of kk hvd
kk hvd
  • 180 Points 100 badge 2x thumb
  • 2
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Yes.
Photo of Not Jeff
Not Jeff
  • 2,058 Points 2k badge 2x thumb
BUT. It does have to be unlocked to work with Koodo. But YES overall.
Photo of Ahmad
Ahmad
Actually, Jeff it doesn't need to be unlocked to work on Telus. That's why David said yes. Telus/Koodo iPhone 4/4S/5/5C/5S/6/6+ are all compatible with the others network
Photo of kk hvd
kk hvd
Ya that is what my question was. Will a telus locked iPhone 6 work with koodo without unlocking?
Photo of Jonathan I
Jonathan I, Mobile Master
Again, yes.
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
I can confirm, yes! Will even work with public mobile!
Photo of Not Jeff
Not Jeff
As a former Public Mobile employee, I warn you that it WILL NOT work. You must get it unlocked first.
And iPhones do not work with PM data services. The limitation being that you cannot add the PM APN to the phone.
Know this before proceeding with Public Mobile!
Telus/Koodo iPhones ***WILL*** work with Public Mobile without unlocking, Not Jeff.  The issue currently is MMS which Apple needs to fix in their end.  The data part can easily be fixed by adding a new APN that is identical to that of PC Mobile (sp.mb.com).  And the newer Public SIMs are already provisioned with the correct APN for data use.
In fact, when I tried my Public SIM in my MotoG, data even worked with my Koodo APN (which was selected by default).
Photo of Robert
Hey peeps, why not go to a Koodo store and try the SIM? Easy-free and if it doesn't work, then return the phone back to Telus. Best way to be sure it works!
Photo of Cameron
Cameron
  • 922 Points 500 badge 2x thumb
I use my TELUS iPhone 6 on Koodo right now. Works just fine and its not unlocked. iPhone 5s worked fine aswell also locked to TELUS. So yes it will work.
Photo of Susan Hwang
Susan Hwang
Did you have to change any settings for it to work on Koodo?
My 5s originally with Telus isn't connecting to the Koodo network
Photo of Inder Singh
Inder Singh
  • 80 Points 75 badge 2x thumb
I wasn on Telus and switched to Koodo. And it worked without unlocking. .. so, yes Telus phone will work on Koodo
