Will my phone successfully roam on a GCI network?
  • Updated 2 years ago
I'm traveling to the middle of nowhere, Alaska (Atqasuk, AK), and there is GCI coverage. My question is whether my Koodo sim card will successfully roam here (with data). From what google tells me, T-mobile customers roam to GCI so I'm hopeful but I don't want to waste money on a roaming package if it won't work. Thanks for any help!!
Photo of Heidi Swanson
Heidi Swanson
  • 124 Points 100 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
  • 93,460 Points 50k badge 2x thumb
Telus does not partner with GCI, so it is likely Koodo does not either. You could unlock your phone, and pick up a GCI prepaid SIM, if you are stopping in Anchorage on your way. Else, your host may well have internet available to you.
Photo of BobTheElectrician
BobTheElectrician
  • 67,236 Points 50k badge 2x thumb
If you are going to be there for a while, pick up a Tracfone + airtime / data at a Dollar Store. They operate on Verizon or AT&T. Check the local ZIP ahead of time to see what's recommended.
Don't expect too much from Koodo or any Canadian carrier in terms of exotic roaming. Even native coverage in Arizona, Nevada and other remote relatively uninhabited areas can be dicey.
Photo of David
No Verizon or ATT coverage in Atqasuk, AK, or anywhere nearby. GCI is the only player!
Heidi Swanson
Thanks so much!!! I unlocked my phone and will nip out for a SIM card in Anchorage! Thanks again!
