will koodoo unluck a telus phone?
  • Updated 2 years ago
telus is sister company to you can you unlock my phone
Photo of Skye Majore
Skye Majore
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 101,454 Points 100k badge 2x thumb
No need to unlock because it will already work with Koodo
Photo of Ahmad
  • 96,062 Points 50k badge 2x thumb
This only applies to iPhone so if you get any other phone in the future, it will be locked and you will need Telus to unlock it. Koodo does not unlock Telus phones ans visversa.
Photo of Noel Conway
Noel Conway
  • 210 Points 100 badge 2x thumb
Koodo unlocked 2 Telus Iphones for me after they were on the account for 90 days.
Photo of Melissa
Melissa, Employee
  • 11,708 Points 10k badge 2x thumb
Hey Skye! Just to clarify any Telus phone will work on the Koodo network without needing it to be unlocked and vice versa. Koodo will not be able to unlock a Telus device for you to use elsewhere.  Hope this helps :)
Photo of TLS
Koodo will unlock TELUS iPhones, and TELUS will unlock Koodo iPhones as long as you don't tell them where you got the phone from. I've done it multiple times. They have no idea where you got it from. If you're a long time customer, they won't even check if it has been 90 days or not.
Photo of Canadian Vaper
Canadian Vaper
  • 90 Points 75 badge 2x thumb
A telus phone will work on the Koodo network however if it's an android phone you may have to change the apn to access data.
