Will Koodo 4G LTE work with my phone European Model Moto G5 phone in Toronto?
  • Updated 1 year ago
I purchased a Moto G5 from amazon.ca and I was sent the European Model.
I enquired whether this phone would even work properly in my region.
A list of frequencies/ bands compatible with the G5 were provided as followed:
"Supports LTE on bands GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz) UMTS/HSPA+ (850, 900, 1900, 2100 MHz) 4G LTE (B1, 3, 5, 7, 8, 19, 20, 28, 38, 40)"
Will I be able to use 4G LTE in the Toronto area with this phone?
What are the limitations in other parts of Canada?
I have not purchased a nano sim card yet to check.
Photo of Robert Jenensch
Robert Jenensch
Posted 1 year ago
Photo of David
David, Mobile Master
  • 89,024 Points 50k badge 2x thumb
Koodo uses 700, 850, and 1900 MHZ  for HSPA+
Koodo uses mostly Band 4 (1700/2100 MHz) for LTE and may use some Band 38 (2600 MHz) in some markets.
It should work on 3G for the most part, and in some larger centres where Band 38 (2600 MHz) has been implemented for 4G.
Photo of Goran
Goran, Mobile Master
  • 90,544 Points 50k badge 2x thumb
Specifically if to you go Koodo's coverage map wherever you see lte-a you should get lTE coverage as Telus uses 2600mhz for lte - a.
Robert Jenensch
Hi,
Thanks for the responses, I do in fact get LTE with this phone, and it works great!
The Koodo store rep was also quite helpful.
