Will I be charged anything for call during inter State travel.
  • Updated 11 months ago
Photo of Debasis Das
Debasis Das
Posted 11 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Hi Debasis, what do you mean interstate travel? Do you mean travelling to the United States, or travelling through the province? Or something else completely?
Photo of Goran
Goran, Mobile Master
  • 90,950 Points 50k badge 2x thumb
If you mean within Canada from province to province, then you'll not be charged extra unless you call an international number or exceed your minutes during daytime.
If you mean traveling in the US then you will be charged the same roaming rate regardless of the state you are in.
If you mean nations internationally then you'll be charged according to zone and if you have a roaming add-on.
It's always free to receive texts regardless of where you are. Receiving Cal's you'll be charged depending on location outside of Canada.
