Will callers be charge long distance to call my phone number
  • Updated 2 years ago
I recently open an account with Koodo. I did this in the province of Quebec although I clearly explained to the representative of Koodo that I was moving to Ontario. I asked about long distance calls: what it meant using a a number from Quebec in Ontario. I was told there was no problem as my plan is Canada Wide. However, I’m now discovering that when in Ontario, those who call my number and don’t have a Canada Wide plan are being charge for a long distance call. Is this correct?
Photo of Philippe
Philippe
  • 220 Points 100 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
  • 93,614 Points 50k badge 2x thumb
Yes. Folks in Ontario without a Long Distance plan would be charged to call your Quebec number.
Photo of Philippe
Philippe
Thanks. I wish the representative would have told me that.
Photo of Sophia
Sophia, Mobile Master
You're not stuck with that number, you can change it to an Ontario number at no cost, Philippe.
Photo of Goran
Goran, Mobile Master
  • 97,104 Points 50k badge 2x thumb
Unless you want to change your number and you have decent data amount on your plan, you could always use Fongo or Textnow so you have a local number for people to call you with. It's what I do.
Photo of Philippe
Philippe
Excellent! Thank you both for those informations. It’s really helpful. Plans in Quebec cost less than those offers in Ontario: there was an appeal for me to get my plan in Quebec.
Photo of Sophia
Whichever works best for you :)
Photo of BobTheElectrician
BobTheElectrician
  • 67,216 Points 50k badge 2x thumb
You can also use CallCentric which does not require a wifi connection.
Get a new local number from them and get your calls forwarded to your existing cell over your regular mobile data connection for about 2 cents per minute. Add a SIP box to your cable or dsl modem and you also have a landline.
