will be I able to use add-ons if i will not pay my plan?
  • Updated 2 years ago
I've got a plan (15$ per monts) + bought booster add-ons (mimutes and data). will be I able to use those adds if i will not pay my plan?
Photo of eiko
eiko
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,756 Points 100k badge 2x thumb
No you need to pay your base plan. If you don't pay your base plan for 90ndays you will lose your boosters.
No you need to pay your base plan. If you don't pay your base plan for 90 days you will lose your boosters.
Photo of eiko
eiko
So, basically, it is possible to hold on the payment for couple of months and safe 30$?
Photo of BobTheElectrician
BobTheElectrician
  • 67,578 Points 50k badge 2x thumb
Yes. If you are traveling or don't need the phone, you can ignore topping up for a total of 89 days. After that, you will lose everything including your number, as Paul explained.
Photo of eiko
eiko
Thank's a lot!
Yes it's possible but you won't be able to use to phone at all during that time until you top up your base plan again, so you can't use your boosters during that time, everything just goes on hold till your renew your base plan or until the 90 days. Sorry just wanted to make sure I was perfectly clear.
