Will an unlocked LG G4 H815T work in 4G or LTE on Koodo?
Looking at buying an unlocked LG G4 H815T and wondering if anyone an confirm that it will work on Koodo and in 4G/LTE?
Photo of Robert Quinn
Robert Quinn
Posted 3 years ago
Photo of EmilX
EmilX
  • 7,746 Points 5k badge 2x thumb
You wil need the IMEI for 2 reasons. One to make sure the phone is not "blacklisted" as it will be useless then. And if you already have the IMEI you can put in here:
http://help.koodomobile.com/getting-s...
I'm almost 100% positive it will work though. If you are buying it from these guys you should be fine: http://www.expansys.ca/lg-g4-unlocked...
Robert Quinn
Thanks! Actually, expansys was exactly who I was looking at getting it from. Hard to get the IMEI without first buying and I was hoping to know first, you know? Sounds like I can probably feel pretty secure about taking the plunge.
Photo of Padin Fain
Padin Fain
Same situation... you get yours yet and get it to work?
Robert Quinn
Yup, works great! Got it from PDA Plaza in Montreal.
Photo of J
J
  • 60 Points
Thinking of ordering from PDA Plaza...any problems with your phone after two months?...did they send you the international version?...does the FM Radio RF work?
Photo of Padin Fain
Padin Fain
Yes I got an international version. I know this because when I reset the phone the language and area went to Korean. I had to find a person with a English android device to switch back. Other than that No problems so far. My radio works just fine. Also my battery lasts for ages which is nice. Only complaint is the phone is on the larger end, but I knew that going in to it
Photo of rikkster
rikkster, Mobile Master
  • 68,282 Points 50k badge 2x thumb
Yes, the LG G4 uses 1700/2100 MHz (band 4), which is compatible with Koodo's LTE network.
http://www.gsmarena.com/lg_g4-6901.php
Robert Quinn
Thanks!
