will an unlocked GSM 900/1800/1900 phone work on koodo?
  • Updated 2 years ago
i think the title says it all but ask away if you need any more details.
Photo of satanas luciferii
satanas luciferii
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
You can see by going to willmyphonework.net actually. Koodo/telus use 850/1900mhz for 3G so no it will not work.
Photo of rikkster
rikkster, Mobile Master
  • 68,330 Points 50k badge 2x thumb
Some sellers may only show a partial listing of compatible frequencies. GSM could be referring to 2G GSM. While 2G GSM is not compatible with Koodo's network, there may be other frequencies listed for 3G (HSPA) and 4G (LTE). Providing a make and model number would be helpful or you can look it up yourself as per Goran's suggestion.
satanas luciferii
that link is very useful, thanks. looks like i'm SOL though. damn it. live and learn.
