Will a Telus locked phone work on the Koodo Network?
I have a Nexus 5. According to the IMEI check, the phone will work on the Koodo Network. What I need to know is this. It is a LOCKED TELUS phone. Will I need to UNLOCK it in order for it to work on the Koodo Network? Thanks in advance for any assistance.
Photo of flyersfan
flyersfan
  • 1,654 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,130 Points 100k badge 2x thumb
The nexus 5 is an unlocked device anyways so no worries it will work on koodo.
Photo of flyersfan
flyersfan
Thanks for the quick reply!
NP enjoy your time with koodo, have a great holiday flyersfan
Photo of Papaxiong Boots
Papaxiong Boots
  • 844 Points 500 badge 2x thumb
Nexus 5 is always unlocked even if you got it from carriers. Plug your SIM and you are good to go.
Thanks no need to copy the answer I gave nearly 24 hours ago when the issue was resolved.
Papaxiong Boots
I just looked at his question and provided an answer. You mean I must copy yours if I gave the same or similar answer? Come on...This is a forum. It is free to talk and help others. Not only you have the knowledge.
Photo of Nabil
Nabil, Employee
  • 6,866 Points 5k badge 2x thumb
Thank you very much for your support Papaxiong Boots!
However, please avoid duplicate answers to keep things clear and uncluttered for everyone :-). If you need more info about our guidelines, please click here: http://koo.do/guidelines123.
Thanks
Papaxiong Boots
LOL Thanks a lot, Nabil.  Will do.
Photo of flyersfan
flyersfan
OK, Gentlemen. Round Two. Does a LOCKED Samsung Galaxy Note 2, currently on a Telus plan, need to be UN-LOCKED to work on the Koodo Network?
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
No,  should work fine on Koodo.
