will a phone work on Kodoo GSM, 4G, 3G, GPS GSM+WCDMA+FDD-LTE 2G
  • Updated 1 year ago
will a phone with these networks work on Kodoo Wireless Connectivity WiFi, Bluetooth,
 GSM, 4G, 3G, GPS WiFi 802.11b/g/n wireless internet Network type
GSM+WCDMA+FDD-LTE 2G GSM 850/900/1800/1900MHz
3G WCDMA 850/900/1900/2100MHz
4G FDD-LTE 800/1800/2100/2600MHz phone is Mstar M1 Pro Android 5.0
Photo of james
james
  • 94 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
It should work on 3g fine but LTE will not work properly
Photo of james
james
guess i don't know what that means coverage map shows LTE but koodo is only 1700 is that right
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Some towers are 1700,some are 2100 and some are both. This phone will only work on LTE where there is a 2100 MHz signal.
Photo of james
james
thanks
Photo of Robert
Robert, Mobile Master
  • 103,584 Points 100k badge 2x thumb
Photo of John
John
  • 112 Points 100 badge 2x thumb
Hi Robert,  is there a website showing the tower locations and frequencies?  I'm in a similar situation thinking in buying a phone with these 3G and 4G frquencies support:
3G: WCDMA 900 / 2100MHz (Band 8 / 1)
4G: FDD-LTE 800 / 900 / 1800 / 2100 / 2600MHz (Band20 / 8 / 3 / 1 / 7)
http://willmyphonework.net/
Do you know whether this tool is reliable ?  I hate to have to ask for every phone ...
Kiddos voice/text services run on 3G 850/1900. Based on the specs you're writing, that phone won't work with koodo.
Photo of John
John
ok,  thank you both
