Does Koodo charge you for using wifi at home?
  • 2
  • (Edited)
when using wifi from home are you charged by koodo for air time
Photo of Troy Mills
Troy Mills
  • 2
Photo of rikkster
rikkster, Mobile Master
No. Just remember to turn mobile or cellular data off to prevent apps that may be running in the background from syncing or using data.
Photo of Troy Mills
Troy Mills
new to use how do I turn these off
Photo of rikkster
Which phone do you have?
For most Android devices, go to Settings > More (settings) > Mobile Networks - uncheck the box that says Data enabled or Mobile data, to disable data.
Photo of Troy Mills
Troy Mills
Samsung galaxy discover
Photo of Troy Mills
Troy Mills
have unchecked box for data enabled thanks for your help
Photo of rikkster
You're welcome.
Photo of Rocky Balboa
Rocky Balboa
Exactly! Just make sure your mobile is turned off on the phone to ensure you are connected to wifi. Only airtime is charged when you make/receive a call prior to when your free airtime starts depending on your plan.
