Wifi not working
Hello, I just purchased a new phone with you and for some reason my wifi at my house is not working it keeps saying searching for ip address...
Photo of Melonie Christie
Melonie Christie
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Hi there... Are you sure you entered the right password??? usually when it keeps searching is cause the password is not the right one... You may also try to power cycle your phone, it may not solve the issue, but does not hurt anyone trying!!!
Photo of Camilo_A
Camilo_A
BTW, What kind of phone is it?
Melonie Christie
Its the Samsung S2, Im not good at this tech stuff! Iam not sure if the password is right... my hubby cant remember it... oh dear!
Photo of Iglooman
Iglooman
  • 4,090 Points 4k badge 2x thumb
Is your wifi a standard setup? Due to an odd issue here I use a custom setup that requires me to enter in a static IP and connection information. If you have other devices that connect automatically, it shouldn't be a problem.
Does your phone connect to any other wifi networks? A friend's, coffee shop, etc?
Melonie Christie
I think it is I have never had any problems connecting anything else- I just got this phone so I havent had a chance to try it anywhere else
Photo of Iglooman
Iglooman
You might have to reset your router and then set if back up if you've forgotten your password. Especially if you don't have any other devices that use Wifi to test connection passwords with, or whether wifi is working off your router at all.
If you can get into your router setup (see your manual) you can reset your wifi password easy enough to make sure you know what it is.
Melonie Christie
okay thanks!!
Photo of Iglooman
Iglooman
No problem! That's what we're here for. If you have further questions, or hit any snags, post your problems here and we'll do our best to help! :)
Photo of Issa Barmawi
Issa Barmawi
  • 1,330 Points 1k badge 2x thumb
Try to restart the WIFI router, I had similar problems sometimes, but that is becasue the Router itself refuses new connections, I was having this resolved by restarting the router itself.
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
won't work if she doesn't remember the password :P
