Wifi Connection
  • Updated 6 years ago
  • Doesn't Need an Answer
My wifi isn't working on my blackberry. The wifi connection in my house is working on my computer, but not on my phone. I'm not sure how to make it work on my phone.
Photo of Lindsay Little
Lindsay Little
  • 84 Points 75 badge 2x thumb
Posted 6 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
The #1 go to phone fixer suggestion that I'm sure everyone will tell you is to try taking out your battery and SIM card for about a minute and then try it again.
Make sure you're entering the correct password when you try to enter it on your phone. It just never connects, or...?
Photo of Darko Angelovski
Darko Angelovski
  • 2,772 Points 2k badge 2x thumb
First try to restart your phone than see if it works.
Photo of Ahmad
Ahmad
What are you trying to do on the phone? Do you have a BlackBerry add-on or data plan at all? I know it's your WiFi that's not working but this question is important
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Lindsay, can you provide us with an update to your situation :)?
Lindsay Little
Thanks everyone, I took the battery out for a couple of minutes and when I put it back in it worked again! yay! clearly I'm not very good with technology :s Thanks for your help :)
