wifi not working
since i shut my mobile data use i no longer can get the wifi to work what do i do ?
Photo of Eleanor Bourgoin
Eleanor Bourgoin
Photo of Sophia
Sophia, Mobile Master
We need more information than that, Eleanor... what phone do you have? Have you switched on WiFi on your phone? What WiFi network are you trying to connect to?
Photo of John Burke
John Burke, Mobile Master
What's your phone, Eleanor?
Disabling Mobile Data shouldn't have had any affect on your ability to connect to Wi-Fi.
Have you tried reseting the Wi-Fi from the back of the router?
Photo of Jason Smith
Jason Smith
  • 1,020 Points 1k badge 2x thumb
Yes, I would recommend that you turn your wifi router off and on then try to connect again. Also a battery pull or a hard reset of your phone usually works as well.
If neither of those work, try a full factory data reset on your phone.
If none of these things work, there may be a login error for your wifi network or the device is defective.
Good luck.
