Wifi not connecting
  • Updated 9 months ago
Hi. My lg3 android phone will not latch on to my wifi and when it does it doesn't stay for long the battery also runs outoff juice too quickly I've turned it off and turned it on even took the battery out and put it back in And still nothing. I'm thinking maybe it's the battery can anyone help me.
Thanks in advance
Mark
Photo of mark jay williams
mark jay williams
  • 170 Points 100 badge 2x thumb
Posted 9 months ago
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Hi there!
It is normal that within the time your battery drains faster, try to go to settings, Battery & power saving and then Battery usage, try to determine what is using the most, sometimes could be random apps and in case you don't need them, just delete them.
The WiFi issue, Go to settings, then WiFi and select your network to be able to click on FORGET, and then try to reconnect again... If this does not work, I will suggest a Factory Reset, make sure you back up all your info so you do not lose it...
Let us know how it goes.
Photo of Goran
Goran, Mobile Master
  • 97,238 Points 50k badge 2x thumb
Have you had the G3 for a while? If clearing out any major battery draining things as advised by Camilo_A doesn't work, you should consider buying a replacement battery.
