WiFi Calling
  • 7
  • Idea
  • Updated 2 weeks ago
  • Under Consideration
a lot of us don't get very great service in some parts of our homes. i get around 3 bars of 3g and 2 bars of lte when inside. however in my basement like most people i have one bar only, but i do get a great wifi signal. it would be great if Koodo offered wifi calling just like bell, rogers, virgin and fido have. fido and virgin have the same priced plans as Koodo which is making me want to switch, but i don't want to because i love Koodo.
Photo of cristian sousa
cristian sousa
  • 316 Points 250 badge 2x thumb
Posted 2 years ago
  • 7
You may be in one of those areas with poor service. Have you considered maybe getting a Wilson Repeater? This is an electronic signal amplifier that mounts both In side and outside your building. Best buy has them.
Photo of Lloyd Willett
Lloyd Willett
  • 3,424 Points 3k badge 2x thumb
Those repeaters are very dear i am in the same vote why don't telus and bell just put some small repeaters around the places where the single is weak mini repeater
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Ivan here something may help koodo cosmers
www.fongo.com here for free wifi calling or LTE
Calling chiper then useing phone in day time allos
Grate we going over the us covers you buy useing wifi free in comming and out going
Photo of Taps
Taps
I have Fongo.. great service. Just keep in mind that not all cities are covered in each province. They need to do better on parts of B.C. for sure. I LIVE IN B.C. yet got a Calgary phone number by choice when I signed up. ALSO Fongo uses about .5MB / minute if you are using data ... so 100 MB of data would allow you 200 calling minutes. Just turn data on/ off as needed so other apps don't waste it.
Photo of Paul Walsh
Paul Walsh
  • 60 Points
Koodo provides terrible connection strength in my area of southern Ontario along the Highway 401 - so no excuses. Too many cut-outs and faded voices. CRTC should ensure a certain minimum standard of quality. Then to add salt in the wound, no Wifi calling.  Makes one quickly lose trust and confidence in the carrier.  I'll be switching as soon as possible.
Photo of MoFromTo2018
MoFromTo2018
  • 1,842 Points 1k badge 2x thumb
WI-FI Calling now works for BYOD iPhones 6 and up, SE included (Post-paid), but also for LG V30 (Need to buy one from Koodo). And I’m pretty sure that they will be adding more to resemble the Telus list such as Samsung and Pixel.
What phone do you have? I frequently travel the 401 and don't have connection issues.
Photo of David
David, Mobile Master
  • 89,320 Points 50k badge 2x thumb
Why not get one of the home phone sets that pairs with your cellular? You can then set the base station in a location with good reception, and set your cell phone beside it to charge. The home phone will then provide service throughout your house.
Lloyd Willett
What kind of system are you talking about any name for it because i am living in a place where i only get 1 bar thanks
Lloyd Willett
How would this work is it for your cellphone and would it use your cellphone number
So you put your cell phone and thebase station in a pplace in your home where you get the best reception on your cell
You pair your phone with the base over Bluetooth
The handsets around your home are now linked too your cell and dial through your cell. They also ring when your cell rings.
Lloyd Willett
So it's has nothing to do with your cordless phone its a different i would put this near my Window where i get 1 bar and use bluetooth on my cell say upstairs in my home and have that other base down stairs and that would work ??
I'm not explaining this well
The base station allows the other handsets to use your cell to make calls.
Lloyd Willett
Ok thanks i will check it out look up some information on this
Photo of Mesmashh
Mesmashh
  • 722 Points 500 badge 2x thumb
Google hang out dialer, It's free and it's part of Google hang outs, if you have a android phone this is your answer. I use this when I'm calling the US (free) or when I'm in the US and I need to make a phone call (Free), It is WiFi based it also has really good voice quality.
Lloyd Willett
Do you use your cellphone number with Google hang out dialer and can someone call your cell phone number and it would go through hang out dialer
Photo of David
  • 89,270 Points 50k badge 2x thumb
To my knowledge, no. You may be able to forward your Google number to your cellphone, though.
The use of Google Hangouts dialer, fongo, or other stand alone voice over Internet application moves away from your original intent, of using your cellphone (and number) as your main point of contact, especially at home, where currently you have poor reception.
Other options which may be available to you include:
  • using a VoIP service as your main point of contact and having it forward to which ever phone you pick up (often called multi-ring) this would allow you to have a number of phones ring, and you answer the one most convenient, be it your cellphone, a landline, an IP phone, or a soft phone application on your computer or smartphone.
  • forwarding your cellphone to a landline installed at your house when at home.
  • switch to a provider that supports Wi-Fi calling.
  • switch to a provider with better local cellular coverage.
Photo of Mesmashh
Mesmashh
Yes you can register your number to receive incoming calls from Google hang out, https://support.google.com/hangouts/a...
Photo of David
That's for the Google Voice number, not Lloyd's cellular number.  Also to my recollection, with the exception of a short test in the 403 area code, Google Voice numbers are all USA area codes, so again not meeting Lloyd's requirements.
Photo of Céliane Trudel
Céliane Trudel
  • 80 Points 75 badge 2x thumb
It's very inconvenient that you don't provide wifi calling option. My phone reception at home is very bad and I can't use my koodo phone. Most of the other mobile phone companies do. Are you planning on offering this service any time soon?
Photo of Goran
Goran, Mobile Master
  • 90,990 Points 50k badge 2x thumb
It remains limited to iPhones for carriers that have launched it, no? Don't expect Koodo to have it anytime soon. Certainly no time table will likely be announced.
Photo of David Setton
David Setton
  • 94 Points 75 badge 2x thumb
I would like koodo wifi calling also because I have bad reception in my home.  You would think that this would take pressure off of the cell network and it would help the carriers.
Photo of Goran
You'd think but as it's been stated, it looks like Koodo will be a while yet. There's no known timeline for it coming out at this point.
Lloyd Willett
That's crazy Fido is coming out with WiFi calling and Koodo should have it by now or come out with it early in the new year and catch up with with the rest
Photo of Dwayne_888
Dwayne_888
  • 1,004 Points 1k badge 2x thumb
I know for 100% that Rogers has had Wifi calling for almost a year now. If Fido is just now starting to get it, that's a shocker.
NB: Wifi calling is not unique to iphones while Shaw Go Wifi Passpoint is.
