Why international calls are charged both local and LD charges?
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
About making international calls.
Hello, I just received my e-bill. The fees amazed me. Some of my international calls are charged both the local airtime charges and LD charges. How does that happen? I've already had the Int'l Dialing & LD Saver services and my plan contains unlimited minutes. Please help me to check the problem. Thanks.
Photo of Lingjie Huang
Lingjie Huang
Photo of Dennis
Dennis, Mobile Master
  • 196,856 Points 100k badge 2x thumb
By adding the LD Saver you get 5cents/min rates to china however Anytime Minutes still apply
Please note the footnote in regular sized print in the link below
http://help.koodomobile.com/coverage-...
Lingjie Huang
Oh, I didn't notice that before. Thanks very much. So I have to care my rate plan.
Photo of Chris Petersens
Chris Petersens
If you have unlimited minutes in your plan you are only charged the international LD, so nothing to worry about.
Photo of Dennis
I completely missed that OP has unlimited minutes.
If that is the case you should not be charged for the anytime mins.
Lingjie, give Koodo a call and I'm sure they can fix your bill (*611 on your koodo cell)
Chris Petersens
Hold on, one thing the OP didn't state is if he changed plans recently. If he did and his previous plan did not have unlimited minutes the charges for local, if he didi go over are completely accurate.
Lingjie Huang
Oh, you are right. I just changed the plan. Yesterday I made a call to Koodo customer service and told him about this situation. A good news is that he reduced my charges.
Photo of Dennis
Great catch Chris +1
Chris Petersens
Well, I'm a little pissed at koodo Lingjie. You just stated that you indeed changed plans and therefore the charges were totally legitimate. So, the credit seems undeserved. I guess next time, I will call and ask for a credit because I didn't know I went over my limit. :-(
Chris Petersens
Did you change plans recently Lingjie?
Lingjie Huang
Thank you very much, Chris. Now the problem is solved.
Photo of G R
G R
  • 2,090 Points 2k badge 2x thumb
Local calls should really be called airtime. You are using airwaves to make the call, and that's what you are being charged with.
