Why do my bills keep going up every month when I am not using more minutes?
  • Updated 2 years ago
My bill seems to go up every month. I rarely ever use the phone for calls, only for checking Facebook and sending txt messages. I rarely leave my house and therefore am connected to my home wifi 90% of the time. So why was my bill $89 last month when I am supposed to be paying $75 per month?
Photo of James Birkbeck
James Birkbeck
  • 200 Points 100 badge 2x thumb
  • confused
Photo of KaneSlavik
KaneSlavik
  • 6,464 Points 5k badge 2x thumb
Page 3 of your bill will show you the charges for the month. Have a look at that first.
Photo of Chris Petersens
Chris Petersens
From the sound of it it might be data. Just because you think you are connected to wifi it doesn't always work out like that. Post the 3rd page of your bill (minus your personals) and in seconds someone here will tell you why the charges are going up.
James Birkbeck
I can't find any of that information on the koodoo mobile app. Where is it?
James Birkbeck
Never mind. I just decided to use my laptop to access the full site.
James Birkbeck
BTW... My bill this month is $93.72. Even more than last month.
I am not using much data. I mostly just send and receive plain old text messages. $100 for that just seems more than a bit excessive. Starting to think I made a mistake going with this plan.
Photo of KaneSlavik
KaneSlavik
You have to look at the actual bill. Which means logging into your Self Serve account on your computer then pull up the PDF bill.
James Birkbeck
Here is my data usage from last month:
James Birkbeck
And my texting usage:
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
In the billing section you can download a .pdf of your bill, that will give you an idea from where you're getting charged.
Photo of quasarito
quasarito
I think you're showing the usage of your current billing cycle (which probably hasn't ended yet).
You would need to look at your last bill. From the Self Service, click on the Billing tab, then click the E-Bill sub-tab. Select the latest bill that was issued. The summary of you supplemental charges should be on page 3.
James Birkbeck
I clicked on "Last Month". So it is from the last cycle.
Chris Petersens
You gotta look at you actual bill, not your usage.
Photo of Ahmad
Ahmad
Do what quasarito just said. That usage info isn't going to tell you anything useful.
"You would need to look at your last bill. From the Self Service, click on the Billing tab, then click the E-Bill sub-tab. Select the latest bill that was issued. The summary of you supplemental charges should be on page 3."
If you want to know what the charges are, this is what you do. Not checking your "usage". Check your actual bill.
Photo of KaneSlavik
KaneSlavik
Are you even trying this from a computer?
Photo of Ahmad
Ahmad
He clearly is by the screenshots
My bill is going up every mouth
Photo of Bernard
Bernard, Official Rep
  • 81,100 Points 50k badge 2x thumb
Your bill is not going up Anibal. For the last few months you have been overpaying and the credit on your account has grown to a hefty size. There is a negative sign in front of the dollar amount on your bill, which means you are in a credit position.
