Why can't I send a picture message using wifi?
  • 2
  • Updated 2 years ago
I used to have a BB and LG both with Koodo and recently switched phones to Samsung with Koodo. I only ever sent mms over wifi in the past but I can now no longer send picture messages over wifi. Data has to be on to send mms.
Photo of Gem Safari
Gem Safari
  • 286 Points 250 badge 2x thumb
  • confused
  • 2
Photo of John Burke
John Burke, Mobile Master
You can if Mobile Data is enabled.
You can only send pict/vid messages over the network with your data on.
Photo of Camilo_A
Camilo_A
  • 31,072 Points 20k badge 2x thumb
pretty much as John said, Picture messages or mms is a services that works through the koodo network so your Data has to be enabled in order to work.
Photo of Gem Safari
Gem Safari
I do have it on all the time now as I updated to a larger data package but in the past had mobile data off all the time and it worked with both BB and LG ... :)
Photo of Jonathan I
Jonathan I, Mobile Master
  • 114,364 Points 100k badge 2x thumb
The Blackberry still required a data plan for pic messaging to work. Even if it was something like BB Social - still enabled it.
What kind of LG was it? If it didn't have a SIM card, it was a CDMA phone and those did not utilize the same network that the newer phones do, so it did not require "data" as it was different back then.
Photo of Gem Safari
Gem Safari
Thanks guys ... kinda confusing having my data off without a BB plan regarding social etc. It was the Optimus Chat LG that i had.
Photo of Toni Danielle
Toni Danielle
  • 60 Points
but wont turning data on charge you if you dont have a data add on???
Photo of Robert
Robert, Mobile Master
  • 103,888 Points 100k badge 2x thumb
Yes, if you turn it on while you are not on wifi. So make sure you don't turn it out out of an wi-fi zone.
Photo of Hans Ernestine
Hans Ernestine
  • 144 Points 100 badge 2x thumb
Wait, if I have data on, and I'm on Wifi and want to send a picture in a text message, are you saying it won't charge me for the bandwidth of the picture being sent???
Photo of rikkster
rikkster, Mobile Master
Correct. Just remember to disable data when you're not using it.
