Why a data usage charge with only phone/5 test max usage
Over the last year, my billing includes a Data Usage Charge of between $1.50-$5.25...I only use the phone feature sporadically...no more than 5 texts a month. Is the Data Usage Fee for the texts since they are recorded on my bill as $0. ....JB
Photo of John Smith
John Smith
  • 80 Points 75 badge 2x thumb
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,506 Points 100k badge 2x thumb
If your data is switched on, all smartphones will use some amount of data to keep themselves up to date. Texts do not use data unless you are sending picture messages. Even then the data used is not chargeable.
Photo of John Smith
John Smith
Thank you very much for your reply....since I use the phone only for emergencies, it seems to make sense to have the data button switched off....I can turn it on periodically to allow updates....again thanks for clarifying...JB
Photo of Weedy
Weedy
  • 528 Points 500 badge 2x thumb
You can turn on wifi when your're home to allow updates.
The only reason a phone would NEED to have 3g data on is to receive MMS.
Photo of Sophia
Sophia, Mobile Master
John, you said you use the phone only for emergencies. Do you mean you use DATA for emergencies only or really the phone itself?? Depending on how much you call, you might be much cheaper off with Prepaid than a plan... but I might have misunderstood you :)
