Why my LTE data speed is low?
  • (Edited)
This is the best I have been getting in Edmonton (Download: 12-15 Mbps and Upload: 20 Mbps). I have brought my unlocked galaxy s6 from Wind mobile and it currently has the wind mobile firmware. Do you think that is the problem? The only way to update the firmware to koodo is via odin and I dont want to loose my phone warranty. Please advise.
Thanks,
V
Photo of Vaibhav
Vaibhav
  • 116 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ivan
Ivan, Mobile Master
Does anyone else you know have an LTE-enabled device with Koodo you can test the speed with? But I don't think that your phone is the issue. I've had LTE clock in under 10 Mbps many times.
Photo of Vaibhav
Vaibhav
Tthats a good point. I can try with a phone locked to telus from one of my friend. And btw, this is the usual speed, I never get more than this. I have seen people reporting more than 70 Mbps.
Photo of Jonathan I
Jonathan I, Mobile Master
Depends on the area you're in, how many people are connected to that tower at that time of day, etc. I recommend trying doing another speedtest later at night, outside in an open area, when the network isn't as congested and you have a clear line of sight.
Photo of Matthew Sider
Matthew Sider
  • 2,432 Points 2k badge 2x thumb
Because koodo doesn't have towers in small plices
coverage map show how little koodo has tray to do a
Data wip by holding volume botton up wile Holding home botton down & volume make sure your phone is off this may help
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Hello Jrü, please refrain from reactivating old posts on the Community. We want people to help and respect each other here, we count on your participation to make the Community better everyday :). Please visit this link: http://koo.do/guidelines123 to read our guidelines one more time. Thank you for your understanding Jrü!
Photo of Vaibhav
Vaibhav
I did try to reset the phone to factory setting but it still has the wind firmware. Do you think data wipe will update my phone to koodo firmware?
And I am located in center of Edmonton and the coverage suggests that I should get LTE, which I do. But just the data speed is slower than other people reporting. BTW, how much is the usual speed with Koodo LTE or LTE+ in urban areas?
Thanks,
Vaibhav
Photo of Dennis
Dennis, Mobile Master
  • 196,424 Points 100k badge 2x thumb
I'm at Churchill Square in Edmonton
Photo of Vaibhav
Vaibhav
That is really good speed. I work at UofA and I don't get that speed.
Photo of Jonathan I
The building can interfere with cell signal, especially LTE.
Photo of Jonathan I
I'm with Rogers with an S6 and just did a speedtest inside my house on my bed just north of Toronto. 78mbps down and 7 up. I know they have faster LTE than everyone it seems, but I can barely get 3G inside of the ebgames at Hillcrest Mall near my house, and forget about Pickle Barrel at Yorkdale - my phone barely works there. So there's a trade off to having these great download speeds sometimes - the network hasn't quite evolved enough to keep up with deadzones. I had slightly lower speeds when I was with Telus but the coverage and reception was better so I'm debating coming back.
I also had less calls go straight to voicemail unlike the weekly occurrences with Rogers. It's unfortunately a pick your poison scenario.
Honestly though, anything over 25 mbps download speed is a bit overkill on a phone anyway. I sometimes turn off my LTE and run on 3G/4G the whole day instead to conserve battery.
Photo of Jonathan I
Photo of Mark Kokolsky
Mark Kokolsky
  • 10,722 Points 10k badge 2x thumb
I'm on the Northeast side of Edmonton and just got this in my house on my Note 5.
